RCU Forums - View Single Post - ringed vs. nonringed
Old 02-13-2003 | 12:42 AM
strato911
Default ringed vs. nonringed
A couple more points to consider based upon literature I have read:
Ringed engines are typically more expensive than non-ringed.
Ringed engines take longer to break-in (as Geistware mentioned).
Ringed engines will last longer before requiring service due to compression problems, and compression problems are much less expensive to repair - just replace the ring.
Ringed engines are less efficient (use more fuel for less power), due to blow-by past the rings.
