RE: KMP Beaver: Just started, looking for feedback
If you're using solder on the copper joints, it wont hold up against he exhaust heat. U have to use the copper weld. It is similar to application as solder, but takes about 1200 degrees to melt. Mep gas will work on it.
I have tried the alumaweld rods and it work sometimes. Some failed due to heat and vibration and cracked along the joint
