RCU Forums - View Single Post - Regular guy's Phenom thread
Old 03-09-2007 | 12:55 PM
  #79
glowplugboy
My Feedback: (17)
Default RE: Regular guy's Phenom thread
ORIGINAL: Details 4 Scale
Razor,
Just mount the servos per the instructions using the supplied servo blocks and screws. There's a 1/16 ply plate that's bagged right into the wing structure. Once installed, the servos aren't going anywhere. Take a look at Crazy's first few posts where he has the servos installed. If you need more pictures, I can send you some from my bird. The servos took me about 20 minutes to install and another 30 minutes to hook up everything. There's nothing worse than having to rip out a servo that's been permanently glued in.
Dan
AMEN to that! We r/c combaters do a lot of servo gluing as it is the easiest way to hold servos on combat airplanes, but you can never get the cases perfectly cleaned up after that.... servo removal in a combat airplane is pretty easy, though, we just have a mid-air!
