RE: Tips on removing/preventing engine varnish
So will the anitfreeze method require removing the engine and soaking in heated antifreeze? Or can I brush some antifreeze onto the engine while it's still mounted and then heat it with a heat gun then use a toothbrush to scrap off the varnish?
