RCU Forums - View Single Post - 60 size Engine type
Old 03-09-2007 | 04:27 PM
Skylane's Avatar
Skylane
Default RE: 60 size Engine type
Hi Ron,
I put an OS 61 FX in my Cutlass Supreme. The Cutlass has a short nose as is typical of the late 60-early 70's timeframe so I moved the firewall back 3/8 in. This meant that I also reduced the volume for the tank which is a 12 oz size whereas a 16 oz would be more normal today. But everything fit, so what the heck. The FX is a bit heavier than the older engines, so I may have to move the battery and/or radio gear a bit to get it to balance. It looks like the overall weight will be about 6.5 pounds. The FX should put out more power than the ENYA III I used many years ago, so perhaps some throttle management will be needed which would make the flight duration longer. Or I may just firewall it anyway! Life is short - fly fast!
Jeff
Cessna 182 N9214G
