RCU Forums - View Single Post - Echo BME twin
Old 03-09-2007 | 08:24 PM
  #74
Antique's Avatar
Antique
Default RE: Echo BME twin
Your lathe will have to be perfect if you expect perfect alignment...a better way is bore a hole in a 3/4 or 1 inch steel block...Barely larger than the long end of the crank...Put the shaft in the hole and indicate the rear shaft...Way easier to align it to the front if the block is in your mill vise.....The factory press fit is usually tight enough that pins are not necessary....
