If you are constantly breaking props with an engine that is
not running you probably are not mounting the prop in the correct position.
With the piston near the top of a compression stroke, the prop should be parallel to the ground. This keeps the prop as far away from the ground as possible when landing with no power.
As to the comments from the other chaps - they are correct also, the problem and solution have many variables.
Good Luck
