RCU Forums - View Single Post - Spring returned throttle
Old 03-10-2007 | 08:05 AM
pe reivers
Default RE: Spring returned throttle
If you use a bowden cable operated lever, the return spring is nice to have. The servo lever can be situated, that at full throttle there is hardly any load on the servo, and at idle the throttle stop is active.
For a different setup, the spring can be unhooked.
You have the options to leave it in place or unhook it. That is good.
