RCU Forums - View Single Post - Plane Stand with CG balancing tool
Old 03-10-2007 | 12:35 PM
Attiqs's Avatar
Attiqs
Default RE: Plane Stand (Aluminium)
Hi
I finished the design of the CG-balancing tool. Today I made a test version and it works properly. It is sensitive and not that easy to use than I have expected, but it works.
I used rolled-shaped PVC as the balancing arm and fitted it with a dowel srew with some play between them.
The friction between the PVC and the steel is very low so it has just a small affection to the process.
I think the inaccuracy could not be more than 1mm.
ID:	639199   Click image for larger version
ID:	639200   Click image for larger version
ID:	639201   Click image for larger version
ID:	639202   Click image for larger version
