RE: Which glue for a blade cpp?
Agreed -- some CA will do the trick. Be careful not to 'gob' it on. Just a little drop or two should do it.
Also, CA comes in different thicknesses: thin, medium, and thick are the most common. Thin dries the fastest (instantly) and will run down into cracks and crevices (wicking) better than the others. Thick is good for filling gaps, etc...
For glueing the tail rotor support back on the boom, I would suggest medium. It will cure a little slower, giving you more time to get it on straight.
Thin will work just fine, though... If that's all you have. I'm sure even thick would do the job...
Good luck!
