RE: storage ideas
I use the same basic method waross uses, but I use shelf brackets, the adjustable kind, with plumbing insulation padding over the brackets the advantage for me is I can move them up or down for whatever need presents itsself at the time, smaller space for wing and larger for fuse of course.
then you can pack your planes in tight and store them on the wall. as well as adjust the size as your needs change.
