RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 03-10-2007 | 08:30 PM
  #1030
Barrrick
Default RE: Wheeeeeeee.......... Blade CP!
INSTALLING A HEAT SINK ON THE TAIL MOTOR OF THE CP - was bothering me for a while
Just now figured a very simple solution.
( Everything I considered involved disassembling half the heli, cutting straps, soldering, etc)
The space between the motor casing and the black plastic shaft toward the back only interferes with ONE of the blue "fins" of the heat sink. I took the cutting wheel of the Dremel, cut off about half of the fin and then the heat sink SLIDES onto the motor casing from the top. There is a slight hump of a solder joint to ride over but with care and a micro size pair of tweezers it CAN be forced over that. Slather some white sealer on the casing, slip the blue aluminum over that. I had considered disconnecting the wire from the 4+1 etc etc....SIMPLE is MOAH BETTAH
and that's ALL I AM GOING TO SAY 'BOUT THAAAAT ......Forrest G
