RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 03-10-2007 | 08:37 PM
  #1031
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Lookyj,
Hmmmm, trial and error and some more $$$$$. As I mentioned, I got the stuff for the CP/Pro, head assembly in, installing the grips tonight and the tail mount in a couple day. Total cost about $60. I'm frugal(cheap).
TIP TO ALL:
When adding several modifications, just do one at a time, test fly and make sure it does what you expect it to do. If you add 2 or 3 at a time, you won't know which one caused your probem. Hopefully no problems.
ORIGINAL: lookyj
choppers,
I agree the CNC head assembly makes a world of difference! Glad to hear just replacing the center hub makes an improvement.... I went with the entire CNC head assembly from microHeli but pretty costly at $120. I'd be interested to see how much difference there is between replacing just the center hub to CNC at $20 vs the entire head assembly at $120.... hummmm, looks like I got another question I'll have to try and answer.
Wheeeeeeeeeeeee Blade CP CNC!
