RCU Forums - View Single Post - Install G90 on CPP
Old 03-11-2007 | 12:52 AM
choppersrule
Default RE: Install G90 on CPP
Rsking45,
After you intall your G90 gyro, you have to turn off, per say. The gyro trim in your 3n1, should be turned all the way counter-clock wise.
Also, when adding any componet, you have to re-adjust your proportinal trim... That may do it .
Dave / Choppersrule
ORIGINAL: rsking45
Hello,
I bought the G90 today hoping that I will beable to get a good hover.I got it installed as per the instructions .I would geuss that the leads need to be plugged in a certin way.The tpo wire on the rudder lead going to the g90 in orangeI have the lead from the g90 plugged into channelChannel 4 and the yellow leadto channel5.the g90 rev and the servo mode are set right.I tryed to get it to hover and the tail spins to the left. Can someone help me out
What does single mode and duel mode mean all I want to beable to do I hover for now
