ORIGINAL: tkg
Its the port timing that counts. The gasket and deck heigth will both effect the dial indicator.
I believe it will be the same exact port timing that counts.
Unless the port timing is matched the engine will not be optimized.
Deck height needs to be maintained so the compression raitos will be he same.
It should not be hard to do, it's just another small detail that needs to be taken care of.
