RE: Q500 engine?
P.,
There are very few Quickie engines, of any make, that are capable of spinning at such high RPM.
20K is more like it and you will want to use the #3246 Quickie tuned silencer.
For higher RPM the #3247 is even better, but its availability is quite limited, as is its effective RPM range.
It is a full bore racing pipe, designed for the discontinued #3070R/F GRRT and GRFT engines.
