RE: axe cp thread
Markind,
Here's a "tip" for nose in FF and nose in hover flying. When your heli's cyclic "disc" is tipping left side low, imagine the radios aileron stick is a magic finger you can use to point at low side of the disc to push/tip it up in a corrective fashion. So if low side is left, push stick left and vice versa.
Before long you'll be performing nose-in hovers better than tail-view hovers. For inverted flight it's the same for aileron, but the elevator controls get reversed.
