ran car with the Hpi aa5 and 13 and 18 th clucth bell
Ok I just installed the HPI setup for the Tornado xp.. The hpi A885 and the 13 and 18 tooth clutch bell.. AWSESOME is all I can say. I love the low end power and when it shifts it has decent high end also. I only have 1 ? on the install of the clutch bell. When I put everything together I notice the only thing that tightens down is the bearing, I used for the clutch bell. I used the stock washers that came with the tornado clutch bell. SO what I am trying to say is after I put everything in and tighten it down I can slide the clutch bell right off. The only thing that holds the clutch bell on is when I mesh the gears. It runs great like this I just want to know if this is the correct way to install the Hpi clutch bell. Any input would be greatly appreciated. Thanks FONG
Sorry I screwed up the thread headlines ITS THE HPI A885 clucth and the 13 and 18 clutch bell from HPI
