RE: Redcat Racing Tornado Thread
I found the problem. It was the wheel rubbing on the hub carrier. I tightened it so it wouldn't come off, but it was dragging, I unsnug a little to turn now is working fine, but the wheel comes off after 1/2hr run time. I also found grit in the dif from sand mixing with the grease. I also put back in the original clutch with the traxxes spring, runs great now. Only thing left is to replace the pipe, since I broke from a wipe-out, LOL.
