RE: ran car with the Hpi aa5 and 13 and 18 th clucth bell
the first pic is the bearing needle and the second is the first way I set the car up inside the buggy with the gear mesh just holding the clutch bell on and the second is with 1 of the washers holding the clutch bell on. U can see the washers are to big to go inside the bell. What i am trying to explain is there is nothing inside the clutch bell to even hold the needle bearing in. So the second picture is the only way I can hold the needle bearing into place inside the clutch bell. When I do that the clutch bell will just slide right over top of everything.
