Hey guys (yep, I don't think there are any gals around here...),
I got my Axe ready for testing again!
BUT, I went and installed the Flat Bottom main rotor blades from the
Blade CP. My LHS doesn't carry Helimax in stock (but they offered to order anything I needed). I removed the top plastic shim, and they went in pretty well.
The hole is a bit bigger than the screw though. My thought was to get the bit from the shim that actually goes in the hole, then it will be a snug fit top and bottom.
Any other tips or dangers to be aware of when going to Blade CP main rotor blades?
