RCU Forums - View Single Post - Official HPI MT2 Thread
Old 03-11-2007 | 05:21 PM
  #13673
djheptic's Avatar
djheptic
Default RE: Official HPI MT2 Thread
ORIGINAL: Crockski
Cheers lads, its a stock MT2, T-15 with rotostart. The fuel tank has a priming button, which i understand is susceptable to air leaks. I've tried checking for air in fuel pipe, but its difficult to see due to colour of pipes, can't see any bubbles though. I've tried two new glow plugs, to no avail.
I think its time for a little dismantling......lol. Just hope i can put it back together again, without any bits left over......
What parts would you recommend i upgrade, may as well hop up while its in pieces.
Straight after the engine stalls check the fuel line, see if you can spot small air bubbles in the fuel line, if there is that means it is the primer on your tank leaking. Allow air in to the fuel line will cause the engine to lean out which, in theory will cause it to over-heat and stall. I would not dismantle the engine unless you are 100% sure you know what your doing. I would start with the basics first like fitting a primerless 100cc tank first, this could sort your problems out. If this fails then i would seal the engine head gasket with gasket sealent. If your looking to upgrade parts on your car firstly i would suggest you get a FAILSAFE i would also get the gpm/edit steering knuckles as the plastic ones are very weak and cause you to loose screws. Another good investment would be a fuel filter & a high performance air filter.
EDIT:- Also check your MANIFOLD screws, The smallest ammount of play can cause problems.
