RE: Four Star 60 Firewall
Time to make lemmonade. I would really think about adding a cowl and turning the engine on it's side while you are at it. I just finished my 4*60 and flew it for the first time Friday. I was thinking I should have bashed the kit and done the two changes. I did use tapered aileron stock and replaced the stock ailerons. I also deep sixed the CA hinges for Dubro pinned nylon hinges set with epoxy.
Were you able to determine if a hinge let loose, or a control rod popped off a horn or servo arm?
Don
