RE: gas fuel with glo plug no ignition
There was talk on a thread that basicly said with 2 glow plugs you could advance your ignition timing.
You would run 2 different heat ranges and a higher rpm the 2nd glow plug would heat and change/advance the timing.
Someone said years ago it was a common practice. It made sence to me but have not found enough evidence to try it.
