RE: Batteries?
Hi
I recall trying to solder copper wire on nicad batteries years ago and found that the solder would not stick to the terminals. tried scuffing with sandpaper and using acid flux, etc. No luck. I was using electrical silver solder. What do you use if you attempt this proceedure?
