RCU Forums - View Single Post - axe cp thread
Old 03-12-2007 | 08:58 AM
  #453
StrykerIncognito's Avatar
StrykerIncognito
Default RE: axe cp thread
ORIGINAL: []TEX[]
That's absolutely wrong, throttle trim should be half way during flight.....
Regardless of whether it's wrong or right, it has reduced the sensitivity of the throw of the throttle stick, and reduced the top end values of the throttle itself, thus making the radio, overall, easier to handle for a beginner.
In the past few days I have played with the throttle trim more and more, bringing it up a little at a time, so as to give myself more lift as I felt myself getting more comfortable with the controls. Having the throttle trim down prevented me from launching the bird into the ceiling or worse while learning.
If people have issues with any one suggestion on this thread, the simple though is, 'If it doesn't help you, don't do it.' As beginners people should realize that there is much to be learned, and anything that makes your life easier is a helper. If it doesn't work for you, put it back to the way it was before you changed ANYTHING. (You did, for the record, document what the configuration was before you made changes, right?)
