ORIGINAL: eugenefelisco
Hi I need help on my set-up. Here is my set-up AXI2212/26 with 10x3.8SF,phoenix25,3TP1320,DX6 radio with 2HS55 and 2S75. My question did you guys do the right trust angle on the motor mount with AXI? And I need suggestions where I can put my HS55 and s75. Thank you very much.
I put right trust into my 2212/26 by using the two wedges provided in the kit, just follow the directions. The motor sticks out a little farther then I like (even when cutting back the motor mount stick) but it balances fine.
I would use the HS55 on the aileron and the S75 on the rudder and elevator but, you can reverse that. It really won't be a big difference.
Its a fun plane to fly I had to put in some mix in during knife edge flight, it pulled toward the gear on left rudder and pulled toward the canopy on right rudder.
Steve
