RCU Forums - View Single Post - Silver soldering
Old 03-12-2007 | 11:33 AM
jaka
Default RE: Silver soldering
Hi!
Agree!
Stay Brite "silver solder" lead/tin solder is actually a low temp soft solder which is soldered with a soldering iron like a Weller. Real silver soldering is the same as brazing and you need a propane torch or acetylen welding equippement!
For Model flying soldering low temp tin /lead is only what's needed. Not even Say Brite "silver solder" is necessary.
ID:	640789   Click image for larger version
