RCU Forums - View Single Post - Brillelli/Extreme Flight COMBO!!!
Old 03-12-2007 | 02:19 PM
  #161
RJConnet
Default RE: Brillelli/Extreme Flight COMBO!!!
ORIGINAL: STG
ORIGINAL: RJConnet
Here you go,
I haven't been sorry for even a little moment since ordering this Combo. from you Scott............RJ
12 Lbs. 2.8 Ozs. with 10oz of batteries!
Looks great! Nice Pictures. Have any pictures with cowl and canopy off that you could share?
How large is your air exit on cowl cut out?
STA, Here's several more pix. I read your post in the gas engine forum, my B46 came with a Zama carb and I have noticed none of the sensitivity you mentioned. The only change I have made is to richen the hi-speed needle about 1/8 turn when I added tubing to the static port and moved the port out of the prop wash.......... RJ
ID:	640869   Click image for larger version
ID:	640870   Click image for larger version
ID:	640871   Click image for larger version
