RCU Forums - View Single Post - Smooth Stop Help
Old 02-13-2003 | 09:00 PM
S_Ellzey's Avatar
S_Ellzey
Default Smooth Stop Help
Hello,
Does the large brass tube that the push rod and airline go into move out with the pushrod? The tube should track the movement of the pushrod exactly. If this is the case the SS is working correctly, and it may be the "o" rings in the brake hub are a bit tight. If the brass tube is not tracking the push rod what is it doing?.
Steven
