RCU Forums - View Single Post - JUST ARRIVED -- SOMENIZED YAK-54, 49" ELECTRIC
Old 03-12-2007 | 11:45 PM
F4dar
My Feedback: (55)
Default RE: JUST ARRIVED -- SOMENIZED YAK-54, 49" ELECTRIC
Hi Guys,
Tonight I had only 1/2 hour so I finished installing the servos/servo arms and links. pretty straight forward. However my Hacker ESC programmer came in and here is the scoop. It has a CD with application, A USB cable and DONGLE you connect to USB and TO ESC RX input. I have included a picture of the interface. Just to remind you, this plane comes with a hacker X-40 PRO SERIES 40amp ESC.
The ESC comes with presets for the following parameters but you can use the programmer to change any if needs be. Here are the presets and the parameters for inputing into the ESC
Factory default settings:
Brake: Off
Battery type (ESC with BEC): 3S Li-Poly (ca. 8,7V)
Battery type (ESC-Opto without BEC): 5S Li-Poly (ca. 14,5V)
Under voltage: Reduce power
Acceleration : Fast
Timing: Auto
Frequency: 8KHz
Active RPM-Control (Helimode / Governormode): Off
So this is what the ESC is programmed. Anybody thinks that any of these parameters should be different??
SO I am going to rap it up for tonight and tomorrow will be getting more building done as soon as I am done with my ESC program. Also as you may know, ESC comes with a switch. I ve heard some people using switch and others don’t. I would appreciate some opinions on this.
Signing off for now,
Jason
ID:	641222   Click image for larger version
ID:	641223   Click image for larger version
ID:	641224   Click image for larger version
ID:	641225   Click image for larger version
ID:	641226   Click image for larger version
