RE: Edge profile help?
don't use two clunks inside the tank. If EITHER clunk gets exposed to air, the engine will suck air and die. So by using two clunks, you double your chance of killing the engine. The clunk should stay in the back of the tank at all times. it should fall to the lowest point in the back of the tank, but it should never fall into the front of the tank.
