hi Richard L,
Great job on your Panther.......I am currently in the same dilema as you are with this project, except that I have lengthened the hull top and bottom at the front and back to allow the roadwheels to be correctly placed.........the real problem is the width though because although the lower hull is about correct, it's the upper hull that is wrong and this governed by the Tiger track width which is too wide.....the new Mato track and sprocket upgrade will solve this but it means changing the roadwheel set-up to suit....what a pain.......I think I will do what you suggest and just buy the Tankzone sprockets and keep the Tiger tracks and drive wheels etc........tank should look real cool even with this anomally............
Cheers
CaptB
