LED Question
Hi Robert,
I have successfully installed a Power Expander, SuperReg, Ignition Regulator and Ignition Cutoff in my SD Models 30% Yak. All worked perfectly on initial turn on.
Question: Do I disconnect the LED bulb or wire connector to the bulb housing in order to mount the bulb outside the fuselage? A 1/4" hole is too small to pass the receiver end connector through isn't it?
After getting everything installed and working perfectly I feel a little silly being stumped by this, but having an outboard LED showing ignition status is too good of an item to leave undone.
As always thanks Robert for these great products.
Best,
Dave
EDIT: Oops, I just noticed the post further down on this subject...........
