I cut 1/2" strips of covering and use the strips to attach the canopy to the fuse.
- Tack on side of a strip to the lengh of the canopy and then locate and tack as needed to the fuse. (Repeat for other side)
- Now apply the iron and repeat in sections for the front and top.
This way, if the pilot should ever get loose (has happened to me
) you can cut the covering and reglue that sucker back in [>:]
