RCU Forums - View Single Post - Motor mount made too small?
Old 03-13-2007 | 07:55 PM
sowega flyer's Avatar
sowega flyer
Default RE: Motor mount made too small?
Without a picture to go by, I assume that the mount is a two piece that bolts to the firewall. When both pieces are mounted to the firewall the arms are too narrow for your engine to fit in between, correct?
If that is the case, you can elongate the predrilled mounting holes on both mounts in order to spread them out.
Jason
