ORIGINAL: Paul Sousa
I have another question, I sent it off to weatronic info email as well,
"I have a question about the DR, if I want to put to servos on the same channel, eg; each one will do a retract valve each, but one is for doors and the other is for the retracts, can I change or delay the time of each servo is activated on the same channel?"
this would eliminate the need for any electronic timming devices, yes?
Paul
Paul can you use the hitec servo programming feature to slow down one of the servos one of the servos to make it work?
Otherwise you can do a mechanical setup that connect a slow servo to both valves. Saw it in a recent RCJett magazine article about the SM F-16.
