RCU Forums - View Single Post - Gas engine BME 110xtreme question???????
Old 03-13-2007 | 09:45 PM
Tired Old Man
Default RE: Gas engine BME 110xtreme question???????
With a little work I can prolly make it run so-so. Give ya hunnert bucks for it.
Work on the low needle a bit. About 1/16 turn at a time. make sure the engine is warmed up before you start tweaking on anything. If you happen to be hitting max rpm in level flight, richen the high needle a smidge after working the low needle. Max power on the upline, not level.
