Tail servo BIG problem
Hi all,
I just bought a walkera 60 and I seem to be having problems with the tail servo. go figure? anyways when I turn on the tx and plug in the battery the servo adjusts it self to neutral but I cannot get any range from it in one direction? It will travel extremely far in one way but not barely at all the other its not a binding problem cause it does it when the linkage is off to. the servo itself only travels reall one way and the ill put the gyro in the reverse direction and it will now travel fully the opposit way and not the other? any ideas this has been the 2nd servo it has happened with. is there anyway that you have to set up the gyro to "program" the servo to travel and if so how? also when its just sitting on but im not touching the sticks at all the servo will slowly creep itself to a maxed out one way position and then it doesnt move at all? can anyone help me with this it is very frustrating. thanks
natew
