RCU Forums - View Single Post - I need technical help...PLEASE!
Old 02-14-2003 | 03:59 AM
den1tjb
Default I need technical help...PLEASE!
My suggestion might be a little tough, but build a new fuse. Most of the tough parts should be done. All you really need to do is trim up a new fuse!
Again, this may be more work than you are up to, but if you have to cut too much off, moving the wing back to re-balance would reduce the distance between the wing and tail feathers too much, thus reducing your pitch/yaw sensitivity too much. That was all kind of a mouthful, so if you need it explained better, let me know. Good luck.
TY
