YS 110 Fuel and Such
I am the proud owner of a new YS 110. This is my first four-stroke engine and look forward to running it on my WM Extra 330.
First question = What is your "take" on running Morgan Cool Power 25% Pattern Pro fuel?
Second question = Will SIG castor oil work OK for oiling the cam gears prior to initial start? I presume only a couple of drops applied down the valve pushrod tubes will suffice. Please correct me if I'm off target.
Last question = Once the engine is broken-in, can I switch to Omega 15% with an additional four oz of added castor, if I find the power to be suitable at the lower nitro range. I hate to carry out different jugs of fuel for different engines.
I thank you in advance.
ED
