RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 03-14-2007 | 10:45 AM
  #1142
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
Putting the plug closer to the incoming intake charge might cause problems with the plug getting cooled off and "doused", especially at idle when the plug is having a harder time keeping hot, or at "idle up", (transition), when sometimes a blast of rich fuel is shot through the transfers if the idle is a touch rich.
I don't see how two (or more) plugs could be used to vary timing. The hotter plug is always going to set off the mixture first....
I think the most productive experiments (with glow plugs) would just be to test various heat range plugs, and see which one a given engine, load, fuel, & atmospheric condition combination likes.... It's going to be different every time one of those variables changes.
AV8TOR
