Well....
With the BME44, you need to install the servos in the tail, or you'll end up adding quite a bit of weight in the tail for balance.
My h9 with the BME44 weighs 14.0lbs dry as a result.....I don't recommend this combo....
The BME turns a 20X10 quite fast, and is NOT needed for this plane....the post below this one talks about the G62 turning a 22X10....This size motor (assuming the data accurate) is NOT necessary for this plane...
Remember that the recommended engine is a Saito 180, an engine that turns 17X8 props.
