ORIGINAL: 2THPIC
seal in org container with a tight led. stored in the bottom corrner of tool chest. dark and cool for the most part. how will i know if the fule is bad or not? is there some kind of test or a type of gauge to tell. kinda like an radiator fluid tester that has the diffrend colored balls inside. Or a burn test of some kind?
Sounds like it will be fine. Give it a good shake before you use it.
There's no real test you can do. The only way to see if it contains water is to see if it's white but it doesn't turn white until you get something like 5% water in it and there's no way you could have gotten 5% in there just by leaving it on the shelf.
