ORIGINAL: Jasonaudio317
You say it has longer run times but the motor is going to use the same mount of fuel regardless right?
yes but once you prime your engine you could top off the tank and have a few more CCs...
Then next time you fill up, you have a full tank + whatever is still in the line. With a fuel filter and long lines you could maybe get 2-3 more CCs...
