RCU Forums - View Single Post - Ultimate CX2 Mod Guide
Old 03-15-2007 | 04:03 AM
  #95
Giles2606
Default RE: Ultimate CX2 Mod Guide
Has anyone tried using ARC motors as a brushless upgrade?
If I remember correctly the stock motors are 37g, I'm not sure of the other specs.
Specs for the ARC's are:
Either
ARC-20-27-80
• ARC 80 watt brushless motor
• Kv: 4500, io: 0.57A (8V), Rm: 100 (mOhms)
• Weight: 29g
• 2mm Shaft
• Dimensions: 20mm x 27mm (w/o shaft)
Or
ARC-20-34-110
• ARC 110 watt brushless motor
• Kv: 3100, io: 0.46A (8V), Rm: 120 (mOhms)
• Weight: 39g
• 2mm Shaft
• Dimensions: 20mm x 34mm (w/o shaft)
They can be seen here http://www.lightflightrc.com/
Is there a way to connect a brushless controller to the 4 in 1? or convert it somehow?
Cheers,
Giles
