RE: Gas engine BME 110xtreme question???????
I tweeked and tuned and tweeked and tuned, and can't get the damn thing to transistion,,,,, I think I was 3/4 out on the low and
2 1/2 on high, however we tryed about ever combination,,,, , it would burp transisiton good on the sticks or with someone holding it,, but as I take the time to taxi out on the runway it just slugs around, and just for FYI someone is probrably thinking it is a air flow problem, but it does it constantly in a hover or what ever,,,,, I can be idling good and started easing to full throttle and then nail it to full throttle and it takes half the runway to start turning up, ,,, and in the air once you can get it to wide open throttle it rips the prop,, but for instance,, I can pull into a hover, and it sounds like it is going to cut off, but while it is hovering at pretty much idle, I can shove the throttle to full to pull out and the engine doesn't even want to change rpms, it just stays pretty much the same rpms,, it wont' even pull out of a hover, , ,I have 3 gallons through the engine now,,
