RCU Forums - View Single Post - The Difference Between......
Old 03-15-2007 | 10:20 AM
Gamesta's Avatar
Gamesta
Default RE: The Difference Between......
ORIGINAL: UNITED RC
ORIGINAL: A.U.S.O
Gamesta : Spend a little on getting the tools needed for making your own tyres champ..
The money spent on a Mitre saw is repayed in the cost of getting ABS piping and doing it yourself..
$4 for ABS
or $40 everytime you need pre-made ones..
I am sure there has to be a contact in your Area, or at least state that can get you some ABS Tyres??
AUSO/Gamester
I have looked everywhere around tampa, and ABS is hard to find. they dont use it much anymore, all plumbing has been switched over to PVC.
PVC is much more "slick" than ABS, there is a noticable difference.......so they are not the same..just and FYI.
What I did was order a set of ABS to get me going, which buys me time to research the local ABS supply.....if you can find one...then great.....if not, no worries, cause you already have the ABS for the car, and you can just buy another set when you need it.
URC
That's a very good Idea Especially if the PVC is slicker I do want some grip not slide wildly.
