RE: Gas engine BME 110xtreme question???????
Jon--Just try slowly leaning the high with each flight until the transition problem clears up. That way you should be perfect on the high for flight conditions without the worry of being to lean. As mentioned by others, keep the low pretty lean where you already are at. Once you get the transition cleaned up you will really like that engine.
If Keith says it sounds rich, it is.
