RCU Forums - View Single Post - Protech Tojeiro-90 build. The last one?
Old 03-15-2007 | 04:23 PM
  #166
wagen017
Default RE: Protech Tojeiro-90 build. The last one?
Well today went flying again with the Tojeiro-90. It flies really well with the 91FX with pipe, swinging an APC 14x10 at 8900 rpm. Today I checked the CG again. Basicly it is balanced perfectly now at app. 16 cms from the leading edge. This is easy to check: without the wings on, I lift the wing tube and the plane stays balanced on the wingtube.
Anyway, today was great flying. The flying of the Tojeiro-90 is much, much better then the Tojeiro-50. Also remarkable is the fact that when you idle the 50, it basicly drops like a brik (let alone if you would have a deadstick). The 90 flies much better when coming in for a landing. This makes you wonder about the discussion earlier on wing load. If this behaviour is decided by wingload, then the 90 must have less wingload then the 50, not more!!
volkert
